All star wire feeder
发表于 2021-8-31 22:10:52 | 显示全部楼层 |阅读模式
I just acquired an all star wire feeder. Didn't give anything for it so nothing invested so far. It came with a half a roll of wire a tweco gun older and regulator. I think it was working when the parked it and bought new welders.( came from a body shop). Is it worth messing with just for hobby home use?Sent from my XT1080 using Tapatalk
Reply:Sure- hook it up and see if it still works.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Finally had a chance to put a cord on it and plug it in. And nothing do not hear the transformer buzzing or nothing. Sent from my XT1080 using Tapatalk
Reply:did you try to weld with it ??? try snapping the power switch a few times. The contacts might be a little dirty.Klutch 220si mig , stick, and dc tigHobart 140 AHP ALPHA 200X 2016Lotos LTP5000DSmith O/P
GMT+8, 2026-1-2 16:07 , Processed in 0.106987 second(s), 18 queries .
