Tig Cooler Pump???
发表于 2021-8-31 22:10:48 | 显示全部楼层 |阅读模式
What GPH do need for a tig cooler pump.... Procon pump that is.
Reply:I have one of these. It is built on a procon pump and the spec is 0.8 GPM @ 50PSI http://www.brweldingsupplies.com/dyn...ooling-system/After buying this thing, I realize how ridiculously easy it is to make your own cooler. Tank, radiator, motor, pump...that's it. If you get the right procon pump, it might not even need adjusting. I read somewhere that the pumps on a carbonator are basically the same pump used in a TIG cooler.Miller Multimatic 255
GMT+8, 2026-1-2 14:32 , Processed in 0.104513 second(s), 18 queries .
