guess which coupon is not pulsed,
发表于 2021-8-31 22:10:48 | 显示全部楼层 |阅读模式
So im on my 5-7th lb of filler.. so im a tig noob..some advice was given to not pulse until I learn to tig at regular settings. (good advice) So I have been setting the machine at 250 amps and just learning to use the pedal. [ATTACH=CONFIG]967171[/so which coupon was welded with high pulse and which one was welded with straight raw power?Both coupons using 3/32 tungsten and filler. Same setup on both plates, except amp delivery. FWIW the center bead was the first one on each plate.  Sorry its upside down.. Attached Images
Reply:Can't really tell from my phone but looks like #2 was high speed pulse. You brushed #1 so it's hard to tellAirco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:What do you mean by pulsed? Throttled pedal, or use of a pulsed machine?
Reply:#2, What's the thickness of your weld plate?I really have no idea what I am doing.Two Shop Cats (not Bobcats...real cats)Miller DialArc 250 AC/DCScratch-Start TIG SetupMIG 175Plasma CutterO/A
Reply:Probably #1 sense it looks a little colder. Your getting good man! Great work
Reply:Oh ya not pulsed lol. I think #2 is straight current and #1 is pulsed. How high of pulse are using?
Reply:Ha, you guys are good. Both were brushed after. #2 was pulsed high speed on the machine. Thing is, pulsed had 110% penetration, I didn't penetration all the way with raw power. Need more seat time. Setting on a 2015 250ex were, left knob was 100, middle knob at noon, right knob at noon. Material was 1/8 aluminum. Gap was 1/8.
Reply:Originally Posted by shaynoakHa, you guys are good. Both were brushed after. #2 was pulsed high speed on the machine
Reply:Get the pic rightside up so folks can tell one from another."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
GMT+8, 2026-1-2 14:33 , Processed in 0.101100 second(s), 18 queries .
