mm 200 up and running
发表于 2021-8-31 22:10:47 | 显示全部楼层 |阅读模式
Finally got my 200 up an running.  So here's a few welds don't laugh to hard
Reply:No laughs here. not sure the application, but I don't see those welds failing unless there is undercut at the bend.
Reply:It's for a Meyers 6.5 hydro turn  so I can mount it to a compact tractor
Reply:Next time try to grind your tacks down first, and wrap the weld around the corners instead of stopping and starting at the corners. Looks like a fun toy.
Reply:Will do next project is welding table
Reply:Don't look to bad at all.
GMT+8, 2026-1-2 14:32 , Processed in 0.099032 second(s), 18 queries .
