lincoln chopper technology arc control
发表于 2021-8-31 22:10:45 | 显示全部楼层 |阅读模式
Correct me if im wrong. But does the arc control knob on lincolns chopper technology adjust voltage?Ranger 305gMillermatic 140 AutosetDewalt Chopsaw2 grindersMy Fists
Reply:No, it adjusts arc force (stick) or inductance (MIG). Higher numbers = more arc force or "pinch".JohnA few weldersA lot of hammersA whole lot of C-clamps
Reply:Originally Posted by bp626indamixCorrect me if im wrong. But does the arc control knob on lincolns chopper technology adjust voltage?
Reply:This covers your question:http://www.millerwelds.com/resources...Control-vs-DigLast edited by Broccoli1; 01-15-2015 at 10:48 PM.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:so i guess it has no effect on voltage? increases amperage to compensate for short arc or lower voltageseems counter intuitive. i like to use my arc length to control puddle size. if the machine fights with me on that, im falling out.explains a lot actually, i naturally run the millers with a stiff arc, as that is what i thought i was doing with my sa (rarely gets over 70 on fine dial and i like it), but with the millers, i have puddles that occasionally end up on the ground. i'll try and soften it up and see what that doesbosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Reply:Originally Posted by 92dlxmani think your on to something. you must know that that is how the sa-style machines work, and it was my first guess too.trouble is, i tried measuring ocv on the tb302 at different settings (4 between soft and stiff) and there was no changejust got a tb 325 that has a seperate dial, similar to lincoln's, and i will have the meter on it soon because im dying to know. but with these machines, it is possible for ocv to stay the same until you actually start welding, so next time i think about it, i plan on having somebody check the lcd readout as im welding at different settings to see what the deal is. im curious also
Reply:What does it cost to replace the board on these machines?I was at my LWS this week, and a guy was loading a new Ranger on his flatbed.  Later I looked out the window, and he was also loading an older Ranger.I asked "What's up with that?"  LWS guy said that the board had gone out on the old one, and he'd decided to buy a new welder.  I didn't ask what it cost compared to a new welder."Any day above ground is a good day"http://www.farmersamm.com/
Reply:FOUND THIS PDF THAT DESCRIBES WHAT IS GOING ON WITH THE ARC FORCEhttp://www.lincolnelectric.com/asset...-400sx-ENG.pdfEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
GMT+8, 2026-1-2 14:41 , Processed in 0.106478 second(s), 18 queries .
