Another Table
发表于 2021-8-31 22:10:38 | 显示全部楼层 |阅读模式
This one is for my grandkids, it will back up to the couch in their den so they can sit there with homework, laptops etc and watch TV. Being the sparky that I am I put electrical outlets underneath as well as USB outlets, and threw in the remote controlled LED tape light for fun. The steel is 1X3 and 2X2 hammered 16 gauge. I wanted a high polish on this one which I got with one of these fitted to a grinder:For the clear finish on the metal I got some mtn aerosol (HVLP) from Ace Hardware, if you haven't tried it it's the best. It sprays like a dream and they sell different nozzles as well for different patterns. I will never use Krylon again. For the wood I got a butcher block top from Floor & Decor and cut it down on a panel saw and finished it with Deft clear oil based laquer. I am starting to like this, and I am getting faster at finishing them and smarter about keeping them square.Miller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
Reply:Sharp looking table!GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Looks good. It's about TV tray high then?"The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:Originally Posted by GravelSharp looking table!
Reply:Originally Posted by SandyLooks good. It's about TV tray high then?
Reply:Looks great I like the power outlets idea. The wood top looks great as well
Reply:Good job. Always nice to build something useful for your family.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:Nice work!Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Very nice. I really like the butcher block top. I'll have to keep that idea in mind. I've found it harder and harder to locate decent butcher block type material for projects. I hadn't thought of going and looking at a flooring supplier.Only thing I'm not sure about is the outlets. If they are up near the front of the table, I wonder if things plugged into them will be in the way when sitting in a chair. If the table is set up with them at the back, that would mean climbing under to plug stuff in, and my back doesn't do that well any more. I also wonder about the weight of some of these adapters that so many things have on the plugs today and if gravity won't be fighting you as the outlets loosen up a bit as they wear.1st thought would be outlets set up in the side of the table, but I'm not finding an easy instal solution for that right now, plus if it gets something next to it, that sort of eliminates those outlets. Best thought I have so far would be those really nice brass floor outlets they sell. That would allow things to be plugged in from up top easily, and the brass won't be too offensive to look at if it's polished a bit. They are obvious in the top however..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Looks great!http://www.lsfdesign.comMiller Millermatic 211 MVPMetcal STSS-002
Reply:Good looking table. I really like the idea of the several outlets.Lincoln Pro Mig 180Lincoln Pro Core 125Hypertherm 30xpPorter Cable Drill PressAcra 7x12 bandsaw48" sheet metal brakeCrap load of other tools, working on metal now.
Reply:Nice. That will last a many a generations.. -Niche
Reply:Originally Posted by DSWVery nice. I really like the butcher block top. I'll have to keep that idea in mind. I've found it harder and harder to locate decent butcher block type material for projects. I hadn't thought of going and looking at a flooring supplier.Only thing I'm not sure about is the outlets. If they are up near the front of the table, I wonder if things plugged into them will be in the way when sitting in a chair. If the table is set up with them at the back, that would mean climbing under to plug stuff in, and my back doesn't do that well any more. I also wonder about the weight of some of these adapters that so many things have on the plugs today and if gravity won't be fighting you as the outlets loosen up a bit as they wear.1st thought would be outlets set up in the side of the table, but I'm not finding an easy instal solution for that right now, plus if it gets something next to it, that sort of eliminates those outlets. Best thought I have so far would be those really nice brass floor outlets they sell. That would allow things to be plugged in from up top easily, and the brass won't be too offensive to look at if it's polished a bit. They are obvious in the top however.
GMT+8, 2026-1-2 16:49 , Processed in 0.433873 second(s), 18 queries .
