Lincoln Commander $1500 Summerville SC clist (not mine)
发表于 2021-8-31 22:10:29 | 显示全部楼层 |阅读模式
http://charleston.craigslist.org/tls/2789236297.htmlNot mine. Might be a deal for someone.
Reply:I went and looked at this machine it doesn't look too bad but the owner says it doesn't weld and he didn't have a battery to start it he claims the generator works fine, but  I was concerned that there may be a bad control board and that a board could offset the good price factor!Squarewave 355300/300 tigIdealarc 250 x 2Weldanpower 225 g7powcon 550smp x2Linc 250 arc x 3Dialarc 250SAE 400 x2  Powermig 200 w spoolgunSpectrum 1000Spectrum 2050Victor cutting torchesBroken XMT304
Reply:If he's not prepared to start it I wouldn't pay over scrap metal price for it.
Reply:That's a series 1 commander.  The board is blown and you can not get a replacement for it any more.  If it was a series 2 commander that board is still available.   That unit is worth about $100.  The duetz diesel is the only thing still valuable on it.Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:What else does the Deutz fit and was that a good engine? A hundred bucks is under scrap in this area.
Reply:That guy wont come off the price any I already tried, those engines are in lincoln/miller welders 100 cfm towable air compressors, Ive also seen them in paving machines, concrete pumps, and light plants.Squarewave 355300/300 tigIdealarc 250 x 2Weldanpower 225 g7powcon 550smp x2Linc 250 arc x 3Dialarc 250SAE 400 x2  Powermig 200 w spoolgunSpectrum 1000Spectrum 2050Victor cutting torchesBroken XMT304
Reply:Originally Posted by Xtreme FabricationThat's a series 1 commander.  The board is blown and you can not get a replacement for it any more.  If it was a series 2 commander that board is still available.   That unit is worth about $100.  The duetz diesel is the only thing still valuable on it.
Reply:Originally Posted by kolot  As far as coming off his price, he will when it stays on CL for a month or more.
Reply:Originally Posted by kolotWhat is the difference between series 1 or 2, I have 2 Commander 300's, neither weld but both engines run OK. Haven't gotten that deep into them but 1 has bad rotor, 1 has bad stator and can see burn mark on control boards. Can boards be replaced, fixed or bypassed?  are these just as junk, would hate to think a machine that costs as much as these new are junk in 10 or 11 years, I beleive they are a 1996 yr model.  As far as coming off his price, he will when it stays on CL for a month or more.
Reply:Haha I offered him 1300$ I'm glad he didn't take it!!Squarewave 355300/300 tigIdealarc 250 x 2Weldanpower 225 g7powcon 550smp x2Linc 250 arc x 3Dialarc 250SAE 400 x2  Powermig 200 w spoolgunSpectrum 1000Spectrum 2050Victor cutting torchesBroken XMT304
Reply:What is the difference between series 1 or 2, I have 2 Commander 300's, neither weld but both engines run OK. Haven't gotten that deep into them but 1 has bad rotor, 1 has bad stator and can see burn mark on control boards. Can boards be replaced, fixed or bypassed? are these just as junk, would hate to think a machine that costs as much as these new are junk in 10 or 11 years,
Reply:Whew, I'm glad I have a 2nd generation. Mine was made in 12/99 so I take it, it's a 2000 model."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
GMT+8, 2026-1-2 16:50 , Processed in 0.093468 second(s), 18 queries .
