F 162 Head Studs/Nuts
发表于 2021-8-31 22:10:22 | 显示全部楼层 |阅读模式
Hi, If you have changed your engine to cap screws on the heads, I need at least two of the nuts and two studs to finish my engine. I may be able to find new studs, but I doubt I will find the nuts new. Thanks!
Reply:try posting this over on the AWS forums theres a bunch of dudes over there running SA200'sVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
GMT+8, 2026-1-2 16:50 , Processed in 0.091434 second(s), 18 queries .
