Cart ideas
发表于 2021-8-31 22:10:20 | 显示全部楼层 |阅读模式
So I just ordered a millermatic 211 with spoolmate, it's going to be my hobby/personal/portable machine. Now I need to build a cart but something mid-size where I can sit the plasm cutter too. I would like to hear some ideas,picture,ect...I tend to over-think somethings and can never make a final decision...I think too much lol.
Reply:You'll find all the pics and threads you'll ever need on the welding projects section of the site.  It's probably one of the most posted threads on the site.
Reply:harbor freight and northern tool both have a cart on sale for $39.00 .miller thunderbolt 250vlincoln square wave tig 175 prolincoln idealarc mig sp250everlast tig 210EXTeverlast power plasma 50chicago electric (hf) 130 tig/90 arcchicago electric 90 amp flux wire3 sets oxy/acet
Reply:Build your own.  Great learning project and u will not be satisfied with a premade one.      If u don't have a smooth driveway/garage. Look at using some solid rubber tires HF has them..  also consider Tipping tendency.   U may find a side by side setup works better than over under.   Check my Welding command center thread.  Sorry can't do a link on tapatalk.   I built that cart and access to the machines was from the side rather than the front Built on an old set of Miller dial arc, 330 factory wheel set.  Back when accessories were built to last.   It stored nicely against the garage wall.   Since changed most of my equipment so now its a storage rack loaded with bags of mortar....Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Here is mine but look over many other carts to fine what you should have on it and what not to do.  If you are putting your tanks on it use big wheel in the back under and outside the tanks.  Don’t make the tank bracket solid straps as tanks sizes change slightly.  Some guys like angled welder positions for better viewing of the controls.  Draws for storage of consumables something to store leads and rods. .  I mounted a box with 2 receptacles and a long extension so I could move the cart around and have both welder plugged in.  Get all the ideas settled in your mind before construction for a better project results.    Attached ImagesLast edited by acourtjester; 11-16-2012 at 11:05 AM.
Reply:Whatever you decide, SECURLY FASTEN THE MACHINES.  Just when you say "oh, I'd never drop my mig", you'll yank it off the cart!  Learned that one the hard way.Lincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:here is the thread on mine  more details in the actual thread  http://weldingweb.com/vbb/showthread.php...command+centerTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Here's mine... hope it gives you some ideas!
Reply:one more......... Attached ImagesMarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:Heres mine, I figured in adding another level on top later for a plasma. So the whole thing is sturdy and stable enough to do so. The height was figured so the controls are easily reached without old guys bending over. Attached ImagesLast edited by jtcnj; 11-18-2012 at 03:47 PM.Lincoln AC/DC 225/125 and WP17. 75A AC is for pipe thawing!HH 140 - new addtion 9/2012.I didn't agree, but hoped for Hope and Change.I got change for myself and my family: for the worse.This is the reality of: Barackalypse Now. Again.
Reply:You will want to avoid those small front caster wheels if you don't have a smooth surface to roll it around on..  just get som 6' or bigger casters and it will roll around a lot betterTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Great carts everyone, I'm kinda stuck between a cart like fullscale and markball2. Fullscale cart is nice and compact but markball2 is wide and spacious. I made a cart for my tig months but it was too compact.
Reply:Here's the aluminum TIG cart with homemade water cooler I made.Alot more pics in the build thread here: http://weldingweb.com/vbb/showthread.php?t=58517Welding/Fab Pics: www.UtahWeld.com
GMT+8, 2026-1-2 16:48 , Processed in 0.099457 second(s), 18 queries .
