What kind of bending brake would i need for this
发表于 2021-8-31 22:10:18 | 显示全部楼层 |阅读模式
I am interested in bending up to 1/4 in aluminum  sheet up to 6 ft long. how many tons for this? most ratings are steel gauges
Reply:Originally Posted by Cdavid82I am interested in bending up to 1/4 in aluminum  sheet up to 6 ft long. how many tons for this? most ratings are steel gauges
Reply:Would it work for 6061T6?  It seems like it would crack.  Unless you need 6061 T6 I would switch to a more formable alloy, perhaps 3036, or 6061 with no heat treatment. Aluminum is tricky when it comes to bending, I might be wrong on the 3036 number, I'll have to check tommorrow
Reply:Originally Posted by blackbartWould it work for 6061T6?  It seems like it would crack.  Unless you need 6061 T6 I would switch to a more formable alloy, perhaps 3036, or 6061 with no heat treatment. Aluminum is tricky when it comes to bending, I might be wrong on the 3036 number, I'll have to check tommorrow
Reply:pretty sure I was thinking of the 5052, the 3036 alloy may have been one I used for angle notching and bending,
GMT+8, 2026-1-2 16:48 , Processed in 0.073761 second(s), 18 queries .
