my 220 has 209v need a voltage transformer ??????
发表于 2021-8-31 22:10:17 | 显示全部楼层 |阅读模式
I need a transformer  the electrician said I have 210 volts in my 220 but I need 230 I asked him if he could set the transformer up on my welding cart   he said yes but that was 3 weeks ago I understand some electrical but where would I find the transformer that I needed aside 600 dollars a little steep anything you can suggest
Reply:I'm thinking you may need a new electrician.  ???230V is the nominal voltage reference that is typically also known as 220V or 240V (usually device ratings).  A 5% variance from 230V is not unusual with as much as 10% (207-253V) considered to be the outter boundry of the limits and if you're seeing these voltages on a regular basis you may want to consider giving your power company a call.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:If that 209 volts is actually supposed to be 230,I would contact the power co.Is your "120v" voltage also low?.If you only have a 208/120 system you may need a transformer. (some 230v.equipment will run on 208.Some won't.)If you do need a transformer, a "buck-boost" circuit allows you to use a smaller,less expensive transformer.Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Reply:Best bet is to give the PoCo a call. If that low a voltage is inherent to your feed and you get caught in an area wide brown out situation you could be at risk for equipment/appliance damage. It could be something as simple as a pot setting/change for them or maybe even a bad xformer."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:I'd measure the voltgage myself.If as low as the electrician said. call the power company - something is wrong.At this point, I tend to think the 'electrian' is full of sh*t, as in...Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Your electritician's meter probably needs new batteries.
Reply:If you want to implement jpump5's buck-boost xfmr suggestion above, here's how.Select a 220v to12v xfmr having a secondary current rating equal to or higher than the primary current rating of your welder.  Connect the 220v primary of your xfmr to the downstream side of your welder's power switch.  Disconnect one end of the welder primary from the power switch and wire the 12v winding between the switch and the welder primary.  Turn on the power and measure the voltage across the welder primary.  If it is the desired voltage you are finished.  If it is lower than the supply voltage, unplug the power and reverse either the primary or the secondary leads of the 12v xfmr (not both). The huge benefit of this approach is that the size, weight, and cost of the xfmr are all about (12/220)th of a 209v/230v xfmr feeding the entire primary power to your welder (if you could find one).awright
Reply:If you have 3 phase 208 one line called the B phase or the bitch will read 208 to neutral and the other two wires will read 120 to neutralThose two combined will give you 220 single phase powerOr in single will give you 120 single phase to neutralAll three hooked to what you are powering gives you 208 3 phaseHope that may helpLast edited by killdozerd11; 11-22-2012 at 04:02 PM.Backed my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
GMT+8, 2026-1-2 16:49 , Processed in 0.071624 second(s), 18 queries .
