SA200 Runs Cold
发表于 2021-8-31 22:10:11 | 显示全部楼层 |阅读模式
I put another chevy 180 T-stat in and it still wont warm up. It runs 160 maybe 170 if running hard, if below 65 degree 130-140. Have new murphy gauge, 1 year old I think. Temp. sender is on the side of head above the starter. Any sugestions? ThanksIts a 1991 SA2001990 SA 200Miller 225  Rip Miller302Miller 135Lincoln 200 MigHypertherm 600 PlasmaPlasma Cam Cutting TableMikita Cold SawJL Welding Tx . com
Reply:Hey JL,You could confirm actual stat operation in a pan of water, with an accurate thermometer.If running  under load the engine temp is staying below actual stat opening temp, my thought would be that somehow the bypass hose is circulating enough coolant to keep temp down. However, that seems unlikely at 65F.  As a crude test you could restrict the bypass and see what happens.Good LuckLast edited by denrep; 01-20-2011 at 01:03 AM.
Reply:Those were my thoughts too denrep.  ???MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:What I did on mind was to put a meat thermometer in the filler neck to get a true read , then go from there. You are right in keeping it at operating temperature, this  prevents sludge and varnish buildup, inside of the mill . Make it run better, go longer. Hope this helps.
GMT+8, 2026-1-2 16:50 , Processed in 0.101803 second(s), 18 queries .
