Lincoln LN-25 power source
发表于 2021-8-31 22:10:10 | 显示全部楼层 |阅读模式
Does the LN-25 require a seperate dc power source?
Reply:Hello Joe, the short answer is: yes it does. It is capable of being powered by either a CC or CV power source. CV is the preferred source as it is generally the type of power source that is coupled to wirefeeders and provides the most desirable operational characteristics. The LN-25 is considered a suitcase feeder and is used in many areas where portability is desired. For a more complete explanation of it's abilities and requirements go to the Lincoln website and research it there. The owners manuals and other publications are available for download and will provide you with a wealth of information. Best regards, Allanaevald
Reply:thanks alot allan
GMT+8, 2026-1-2 16:50 , Processed in 0.069065 second(s), 18 queries .
