Current Control Potentiometer
发表于 2021-8-31 22:10:09 | 显示全部楼层 |阅读模式
Can anyone tell me what the K Ohm and Watt Values are for the current control potentiometer on a Tig 300/300? Code # SPL-B443-84, Serial # AC-576738. I think I found my problem with control board shorting to ground. I shot the wires going through the pot to the board and they are grounded, when I remove the pot from the panel it's not. I disconnected the wires and dont get any change in reading from max to min. So I'm guessing it went south. Any help would be greatly appreciated.link to original problem:http://weldingweb.com/vbb/showthread.php?t=46282
GMT+8, 2026-1-2 16:50 , Processed in 0.115398 second(s), 18 queries .
