sa200 gaskets etc...
发表于 2021-8-31 22:10:09 | 显示全部楼层 |阅读模式
I'm hoping someone here may have a Felpro part # for a sa200[1982] thermostat gasket. Also the same for a thermostat. I'm hoping my local O'Riellys wil have some of this stuff. Also a # for a front crank seal would be great. Thanks very much.Btw part # doesn't have to be Felpro just something that will cross-reference.
Reply:Do you have a Napa auto parts store near you? My Napa store has yet to let me down. Got a cam for an F-162 the next day. Couple weeks ago got a set of valve springs for an F-162 the next day. I don't even take in the manual, I just walk up to the counter and tell them what I want, just like the guy beside me asking for parts for his 2009 Chevy.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:I need to go to your NAPA then Carl!  The one I have by my house if I ask for antifreeze, they will ask me if the car is 4 wheel drive. If it is not in the computer, they are lost. Anymore I just order from Stumpf's, or Bills, weldmart or Hybriweld. Im about 30 minutes one way from any store, by the time I get home and figured out they gave me the wrong part even after I gave them the correct part number Im usually pretty hot!2011 Dodge 3500 diesel duallyLincoln SA-200Lincoln SAE-300LN-25'sLincoln Idealarc R3RMiller Trailblazer 302
Reply:Thermostat gasket, Felpro 1273 or Victor / Reinz C24109      Rear main seal JV663, Front cover gasket set W/ front crank seal  Felpro TCS54182 or Victor JV894. Hope these help, I also think my son used one of my spare Thermostat gaskets on his 250 6 cyl. Chevy, fit good and no leaks, might be able to use that or small block chevy, I know you can use the thermostat. Hope it helps.  I keep a note book of all the part #'s I can find for the F163."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
GMT+8, 2026-1-2 16:50 , Processed in 0.096027 second(s), 18 queries .
