Power factor correction capacitor
发表于 2021-8-31 22:10:07 | 显示全部楼层 |阅读模式
Anyone with a Tig 300/300 know what the microfarad and voltage ratings are for the power factor capacitors?
Reply:Can't even begin to answer with out the code number of your welder. there are about 4 different versions made over 20 years that are quite different.Those caps will help your power use when welding but up your standby power use.So if this is a home unit. Turn it off when not using it.
GMT+8, 2026-1-2 16:50 , Processed in 0.096428 second(s), 18 queries .
