Few Lincwelder 225 questions? - new here..
发表于 2021-8-31 22:10:05 | 显示全部楼层 |阅读模式
Hi Folks- first post..I've welded off/on for many years but only for my own use- building trailers,ect. I just got a old Lincwelder 225 (3-AS) DC welder Given to me. reason is the Onan (CCKA-S 1627 G) motor needs pistons. The bores are super shape. Was taken apart for bearings I believe as it had a rattle- And in process over period of time both pistons fell to floor and broke!..Before I got it of course. Question 1: Is this old welder 'worth' fixing Onan?  Question 2: If I look for doner Engine ( can't seem to get fan off crank to see output end of crank yet) Does this engine have a Taper crank? it is a lt.green engine so wondering if even was original?  Question 3: How do I test the slip rings using a Ohm meter..I know how to use meter..But no Idea what/where slip ring ends are? I hate to invest in motor if windings are shot. Supposedly worked thou. Guess one more- Question 4: Should I try to get Armeture out while motor is off and clean any rust (if any) off armeture and inside where armeture goes?..Big job getting out? - THANKS a million- sorry so many questions- You guys are the ones to ask thou.  Geno
Reply:Welcome to the forum. First you can get the unit manual here http://www.lincolnelectric.com/asset...oln3/im244.pdf where you can make out how the armature is attached to the engine crank adapter (which is tapered to match the crank output) on page 7 of the manual (pg 8 of the .pdf document).  You can also see where the slip rings are at the right end of the illustration.  Can't help you with specific resistance values but at least you can check for open or shorted windings.  Same goes for the commutator.Second, bummer on the pistons.  For all you Onan needs get with member onansales.com (TJ) at his website http://onanparts.com/.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thanks Duane..That is Great help. Will download.  Geno
GMT+8, 2026-1-2 16:49 , Processed in 0.302680 second(s), 18 queries .
