Sa200 soleniod
发表于 2021-8-31 22:10:05 | 显示全部楼层 |阅读模式
I've got a 82 green light sa200 that I'm cleaning up and working the bugs out of[been sitting for sometime]. Can you hook 12 volts up to the soleniod to see if it works ? Is it safe to do so ?
Reply:If you're referring to the idler solenoid - yes.  Keep in mind the idler board controls the ground for the solenoid so if you leave it hooked up, don't apply 12vdc+ to the wire coming from the board. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Soleniod and bracket are off the machine. Was curious if hooking up the two wires to a 12 volt battery would tell me if my soleniod is good or not.
Reply:Yes it will.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:It's dead. Is it possible for it to be stuck ? Didn't make any noise at all when hooked up to 12 volts.
Reply:Do you have an ohm meter to check to see if the coil is open?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I've got a multi meter but haven't a clue what to set the ohms at. 20m , 2000m , 200k , 20k , 200 , or ?  If you didn't notice I'm electrically illiterate.
Reply:200 or 20K would work.  You're looking for infinate resistance - a 0 or .OL reading if the coil is open (bad).MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:20k and 200k I get 0.  On 200 I get 26.5.
Reply:Well now I wish I had a proper resistance value for you but 26.5ohms is far from an open coil.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Make sure the springs aren't broken and missing or needle valve plugged up.  There is a little felt filter can be missing too a cigarette filter or little piece of felt works to replace that.  Solenoid inside should be clean and not sticking.  Don't oil and grease it that will attract more dust and make it stick again leave it dry or just use graphite or dry silicone if anything on it.  Here are links to the R57 idler manuals.  http://www.lincolnelectric.com/Asset...N3/IM179G1.pdfhttp://www.lincolnelectric.com/Asset...OLN3/IM179.pdf
Reply:My idler isn't a r-57.  I guess you would call it a electric idler.Machine is a 1982 model.
Reply:I was going to say something but just figured Fixalinc missed the model year in your original post.  Scared me for a minute and had to go back and check what you said myself.  I was afraid I gave you bad information.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:You still need the plunger clean and dry.  Check all your connections and wires.  Make sure linkages are all working free not binding.  IM-277 covers the electronic idlers.  New link to that manual I recently got from Lincoln after they changed their site and hid all the old stuff now.  Was going to post all 3 and it didn't work but then did later just try it again later if doesn't open. ..  Duane, I think my brain was still frozen from being out in the blizzard we were having up here in the panhandle.  http://www.lincolnelectric.com/Asset...OLN3/IM277.pdf
Reply:Originally Posted by FixalincDuane, I think my brain was still frozen from being out in the blizzard we were having up here in the panhandle.
Reply:We never got above freezing today up here but that wind let up so was still better than the -20 to -30 wind chill had before.  Wind whipped snow into 4 ft. drifts where you didn't want it instead of staying in the fields.
GMT+8, 2026-1-2 16:50 , Processed in 0.100756 second(s), 18 queries .
