Will Onan from miller welder work on a Lincwelder 225?
发表于 2021-8-31 22:10:04 | 显示全部楼层 |阅读模式
Wondering if I could put a Onan from a Miller onto my Lincwelder to replace mine on it? both have taper shaft but not sure if would be same taper? I heard Lincoln is it's own taper?- Thanks.  Geno
Reply:Different tapers but if push comes to shove you can swap cranks.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thanks again Duane- I'm going to think on that. My crank is good- as well as Rods..Just need's pistons. Buying them might be way to go. I know the old Lincwelder isn't worth whole lot so hoping to keep cost down somewhat. I use a Linde wire-feed for most projects. Just thinking the 'mobility' might be nice at times..as well as deeper penetration. My Linde is only 160.   Geno
GMT+8, 2026-1-2 16:47 , Processed in 0.144975 second(s), 18 queries .
