1989 craftsman bandsaw
发表于 2021-8-31 22:10:01 | 显示全部楼层 |阅读模式
Any place to get decent blades? Ole guy bought it new and used it like ten times. I paid 150.Sent from my SCH-S968C using TapatalkHH 190Uniweld TorchesLincoln 225 ac-sMarquette Starjet torches gauges
Reply:Sent from my SCH-S968C using TapatalkHH 190Uniweld TorchesLincoln 225 ac-sMarquette Starjet torches gauges
Reply:If the manual doesn't tell you how long the blade is, then use a measuring tape to find out how long (and how wide) you need.  I've bought a few blades from Enco (www.use-enco.com), they seem OK.  Most recently I bought a Starrett blade for my vertical bandsaw from Amazon.  I started to buy stuff from sawblade.com but when I got to the shipping part I choked and went elsewhere.  They do seem to have a big selection and easy to find what you want - YMMV.What's all that white stuff in the bed of your pickup???Lincoln AC 225Miller Auto Arc 130 (Mig)Thermal Arc 186 AC/DC Inverter (Tig/Stick) - the "no excuses" machine
Reply:Originally Posted by ThobIf the manual doesn't tell you how long the blade is, then use a measuring tape to find out how long (and how wide) you need.  I've bought a few blades from Enco (www.use-enco.com), they seem OK.  Most recently I bought a Starrett blade for my vertical bandsaw from Amazon.  I started to buy stuff from sawblade.com but when I got to the shipping part I choked and went elsewhere.  They do seem to have a big selection and easy to find what you want - YMMV.What's all that white stuff in the bed of your pickup???
Reply:We just picked up 4 inches todaySent from my SCH-S968C using TapatalkHH 190Uniweld TorchesLincoln 225 ac-sMarquette Starjet torches gauges
Reply:I've had good luck with Bandsawbladesdirect.com
Reply:Probably imported by Colovos company, just tape measure the width of the face of the drive wheel and length  and order a blade.
Reply:64.5Sent from my SCH-S968C using TapatalkHH 190Uniweld TorchesLincoln 225 ac-sMarquette Starjet torches gauges
Reply:32332 1 / 2 X 64-Inch Band Saw Metal-cutting Blade
GMT+8, 2026-1-2 16:47 , Processed in 0.098166 second(s), 18 queries .
