Second attempt at tig judge kindly
发表于 2021-8-31 22:09:59 | 显示全部楼层 |阅读模式
Tried some tig on a butt joint on some rectangular tubing   some with filler some with out here are the first 4 sides no pedal  dial arc 250
Reply:likely too long of an arc length and too large filler rod, but we can't be sure unless you disclose everything.  It will help you get better critique if you do. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Looks like you could use more amperage also.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:Was at 70 on the second setting on a dial arc 250 and tungsten sticking out of cup about 3/8 of an inch my cup on a 20 torch is really short  I don't have a cooler set up built yet   filler is smaller than tungsten I'm thinking 1/16
Reply:Originally Posted by large-humanWas at 70 on the second setting on a dial arc 250 and tungsten sticking out of cup about 3/8 of an inch my cup on a 20 torch is really short  I don't have a cooler set up built yet   filler is smaller than tungsten I'm thinking 1/16
Reply:yeah I would look at the hose your power cable is in and look for melted areas  (Will be a sprinkler)anyway the weld doesn't look that bad I would suggest dabbing twice as fast as your doing now. That will keep a bit more heat in the joint but get an air cooled torch first or a chiller for your 20 if the hose isnt melted already    Last edited by B_C; 01-19-2015 at 01:05 PM.  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
GMT+8, 2026-1-2 16:47 , Processed in 0.070358 second(s), 18 queries .
