Lincoln weldanpower 225ac/210dc
发表于 2021-8-31 22:09:59 | 显示全部楼层 |阅读模式
i have found a early 1980's? lincoln weldanpower 225ac/210dc welder for sale for $175, the guy says it need a flywheel ring gear, fly wheel, starter, carb linkage all just engine parts. i was wondering how much you all would think those items would be to replace and if this was a good deal. oh also disregard my last post about the lotos.
Reply:Bought one a couple years for $100, I ended up finding everything I needed for it on ebay and it turned out to be a hell of a welder. I sold it to buy a milling machine and I dearly miss it .  You might be looking at $200+ to get all that plus a carb kit isn't a bad idea, You can find parts on ebay.  Expect to put some work into it and if not up to the task then pass on it.
Reply:alright thanks for the advice, im waiting to see what happens with another welder first but will go back to this one if it falls thru
GMT+8, 2026-1-2 16:36 , Processed in 0.106777 second(s), 18 queries .
