WTB plug for ICE 55c torch
发表于 2021-8-31 22:09:49 | 显示全部楼层 |阅读模式
Looking for the end that threads into the plasma cutter. it appears as though you can only order the whole torch cable from miller. all i need is the plastic bit with the 8 holes for the pins and the one large hole for the air and the threaded collar. Parts circled in red in pic below let me know if you have any of the above and the price you want.ThankRyan Attached Images_______________________OF COURSE I DON'T LOOK BUSY... I DID IT RIGHT THE FIRST TIME
GMT+8, 2026-1-2 16:48 , Processed in 0.073746 second(s), 18 queries .
