Hello,I picked this welder up not too long ago but simply do not have the space for it. It works absolutely flawlessly and was mainly used on aluminum. The MaserTig torch is a few months old but barely used. It has a rotary switch on the handle with the 10 pin Hobart style connector. The rotary switch can be removed if you want to use the pedal. The pedal needs a new rheostat (25k ohm/2w). The welder is on large casters which make it reasonably easy to move around (for 600 lbs). It also has a gas cylinder rack built on the back. This is fairly large machine but has a lift eye right on top so you can use an engine hoist to lift it. It would be easiest to pick it from here on a trailer. Size is 39" x 24" x 36" (L x W x H) Specs are as follows:Hobart 300 Amp TIG/Stick Welder w/High FrequencyModel: TR-300 HF (High Frequency)Serial No.: 83WS05599Spec: 6496-1Amps: 300Max OCV: 80Volts: 30% Duty Cycle: 60 AC TIG 240AVolts: 230/460Amps: 120/60Phase: 1Hz: 60Hobart Pedal:Model: 362668BSerial No.: 83WA03675Specs: Switch - 15A/125VRHEO - 25,000 OHM - 2WWeldCraft Torch:Model: RAC2S-25-2-H10Rotary Amperage HandleRHEO - 25,000 28 Foot LinesHobart 10 Pin ConnectorAll that is needed to start welding with this machine is gas and either an air cooled torch or a water cooler. Looking to get $1050 obo. Located in Tyngsboro, MA 01879. PM me if you have any questions. Thanks for looking!Pete----------------------------------------------- Airco SC HeliWelder 300A TIG- Lincoln HD140 MIG- Hobart - Wilton 3230 Hrztl. Bandsaw----------------------------------------------
Reply:Price drop!!!!!Will let this go for 900 obo!!!!!Let me know what you guys think!Thanks,Pete----------------------------------------------- Airco SC HeliWelder 300A TIG- Lincoln HD140 MIG- Hobart - Wilton 3230 Hrztl. Bandsaw----------------------------------------------
Reply:I think Hobart makes the BEST boat anchors I every used!!!!!!Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain |
