2,000 holes.
发表于 2021-8-31 22:09:48 | 显示全部楼层 |阅读模式
Yep, I got REAL bored, REAL quick. They are riser brackets for antenna mounts on commo generators.If you cant fix it with a hammer, it must be an electrical problem."Boy, everyone starts with a full bag of luck and an empty bag of experience. The trick is to fill the bag of experience before the bag of luck is empty."-Grandad circa 1990ish
Reply:You need to get some of these ...I think you can get them in bulk if you have a lot of one size. Attached Images"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Originally Posted by OldendumYou need to get some of these ...I think you can get them in bulk if you have a lot of one size.
Reply:Lol @ bolt hole assortment.  I feel for ya.  Recently had a job that called for 500 holes. 200 @ 7/16, and 300 at 3/16.  200 pieces.  Angle iron and flat bar.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:There is a reason they invented CNC...
Reply:Originally Posted by Mick120Cool....wonder if they have those here in Aussie..........
Reply:Can you fit 2 in the vise at once? Or a no-no?Bruce
Reply:Originally Posted by Bruce AvisonCan you fit 2 in the vise at once? Or a no-no?Bruce
Reply:If you want to go cheaper just buy the hole in bar stock, comes in 12' lengths. Cuts down on waste. Also can get post hole size from same supplier!
Reply:I feel your pain. Did you have to debur them all too?I use various sizes of ez-burrs and cogsdill burraways that break the edge of both sides and save a ton of time. If can also get a drill/burr that does both in one step. I saved a lot of hand work on one part with a lot of holes and all it require was a tool change.[ame]http://www.youtube.com/watch?v=pCqUPzHCDfg[/ame][ame]http://www.youtube.com/watch?v=vlljJNmwuoo[/ame]Last edited by forhire; 09-12-2012 at 12:13 AM.
Reply:Oooo, a deburring tool.  I normally grab a random, much bigger drill bit and have it in the extra drill for deburring.
Reply:THiiiiiiis is what you need[ame]http://www.youtube.com/watch?v=L5aC5Kpvibc[/ame]Don't we all.... Don't we all...Last edited by Zmechanic; 09-12-2012 at 09:03 AM.
Reply:Originally Posted by ZmechanicTHiiiiiiis is what you needDon't we all.... Don't we all...
Reply:2080 LF of galvanized and powder coated handrail coming up next month.  12,000 3/8" holes in 1 1/2" schedule 40 pipe for draining and venting.  Oh, it's gonna be fun.
GMT+8, 2026-1-2 16:49 , Processed in 0.111953 second(s), 18 queries .
