Acetylene not coming out of torch
发表于 2021-8-31 22:09:44 | 显示全部楼层 |阅读模式
So I picked up a Victor HD310 handle with a CA2460 head from a garage sale for $15 this morning along with some other tools and I just tried it out the torch and I can't hear the Acetylene coming out, I can hear the Oxy though. I tried to light the acetylene and it has about a 1/2 inch flame but I no matter how much I adjust it it stays at that size. I'm taking the torch apart to see if something is clogged, any ideas?"Firearms stand next in importance to the Constitution itself. They are the American people's Liberty, Teeth, and Keystone under Independence." - George Washington
Reply:Perhaps someone tried running their torch set laying down, and the acetone went into the hoses and gooped everything up?Unless something is physically smashed shut, it's nothing a thorough cleaning shouldnt fix.You didn't build that.'85 Miller AEAD-200LE
Reply:Originally Posted by anickodePerhaps someone tried running their torch set laying down, and the acetone went into the hoses and gooped everything up?Unless something is physically smashed shut, it's nothing a thorough cleaning shouldnt fix.
Reply:That torch I believe has flash back arrestors in it. I think the flashback arrestors "melt" and shut down the gas flow when activated. They also have built in check valves, but I doubt they are the issue.I haven't seen OAdoctor around lately, but if you contact him thru his website, I'm sure he can get you the parts you need to get this running again.http://www.regulatortorchrepair.com/repairservices.php.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:There's a dead spider in there from laying around!I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by weldermikeThere's a dead spider in there from laying around!
Reply:Originally Posted by Jeromy_EI got it working, there was so much black gunk built up in the gas valve and there was actually two dead spiders in it haha!  There's a really weird buzzing/humming sound coming out of the middle of the torch where the handle and head come together, it only happens when I have the acetylene turned on. I haven't ever heard it before on any of the other torches i've used. It works like a champ though, I just cut some 1'' steel plate with it and it works much better than my smaller Victor torch.
Reply:I left my cutting head off the body since I got a plasma, had the rosebud on the body. Went to use the cutting head the other day and neither O/A came out the tip. Turned out Mud Dauber wasps plugged the end of the torch with mud. Had to remove the Oxy valve  and clean it out, works fine now.
GMT+8, 2026-1-2 16:25 , Processed in 0.114782 second(s), 18 queries .
