Can I run my 140c off my Ranger 8 ?
发表于 2021-8-31 22:09:44 | 显示全部楼层 |阅读模式
This is going to sound like s dumb question but I'd rather look stupid than burn up my 8.I hrecently bought a 140c mig. The outlets in my garage cannot handle the machine. It will blow hte breaker if I weld too long with it. I need to run a dedicated outlet to my garage for it but is it ok to run it off the aux power on my Ranger 8? It' seems to work very well. In fact the Mig seems a touch smoother ?? Placebo effect ? I'd lkike to ideally get a ln25 but as a hobbyist who doesn't leave the garage I could not justify it. The 140c is a nice machine.Thanks.Lincoln Ranger 8Lincoln 140c MigLincoln Tombstone(doesn't everybody have one ?)Miller 200Diesel/Heavy Equipment MechanicLead Plant Mechanic Municipal Water
Reply:You'll be fine KennyWhen my shop was being built I used my miller Bobcat to run my old Miller 250 CV with a wire feed. It isn't as smooth as a good electrical service but I welded a lot of hours this way.Leo
Reply:Thanks. Wanted to make sure.Lincoln Ranger 8Lincoln 140c MigLincoln Tombstone(doesn't everybody have one ?)Miller 200Diesel/Heavy Equipment MechanicLead Plant Mechanic Municipal Water
Reply:I am not familiar with the 140C , is that a 115 or 220 volt machine. The reason I ask is I have and old miller side kick 115 V machine rated for 90 amps. It will run from a 15 amp plug but it is recommended to be run from a 20 amp plug. Most of the time the 115 outlets are 15 amp uless it's for the microwave or AC. The 20 amp line does make a noted difference and improvement. I believe the plugs on the Ranger are rated for 20 amps. You may just need a 20 amp line and plug in your garage from your existing service. You will need 12 guage romex and plug to get it though, that is if it is a 115.Last edited by kolot; 02-10-2011 at 12:13 AM."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:It's a 110v machine. Yes the outlets in my garage are 15 amp. I need to run a 20 amp but everything is under 3 ft of snow and frozen, so that is not happening for awhile....Lincoln Ranger 8Lincoln 140c MigLincoln Tombstone(doesn't everybody have one ?)Miller 200Diesel/Heavy Equipment MechanicLead Plant Mechanic Municipal Water
GMT+8, 2026-1-2 16:25 , Processed in 0.125161 second(s), 18 queries .
