ive not been able to find much literature on my ranger225gxt.i always see the ranger225 dc machine in catalogs. the gxt can weld on ac and the ownerx manual says all outputs rated 100%duty cycle whereas the"standard"225 says 40% at 225amp dc only. is it an oddball that was phased oyt by the 250gxt?.lincoln weld pak 100 hdlincoln ranger 225gxt ac/dcoxy/acetylenepuroxcw202 victor fc100harris model 85harrismodel 16oxweld w24roxweld w17
Reply:Looks like the 225GXT was replaced by the 250GXTLook up what you can power with the aux power with these welders. There are a lot of limitations.
Reply:it can run an ln 25 wire feeder, a precision tig 225 and a pro cut 55 plasma. its identical too the 250 xcept the xtra25 amps and 500 watts more generator output.the date is june 09 on the tag.lincoln weld pak 100 hdlincoln ranger 225gxt ac/dcoxy/acetylenepuroxcw202 victor fc100harris model 85harrismodel 16oxweld w24roxweld w17
Reply:2 115volt 20amp duplex and one 250volt 50 amp.10,500 watts peak 9200 continuos.lincoln weld pak 100 hdlincoln ranger 225gxt ac/dcoxy/acetylenepuroxcw202 victor fc100harris model 85harrismodel 16oxweld w24roxweld w17 |
