Online aluminum dealers
发表于 2021-8-31 22:09:39 | 显示全部楼层 |阅读模式
Where is the most affordable place to order aluminum sheets online?Sent from my SM-G920P using Tapatalk
Reply:Depending on how much you need and if it would be worth the drive Research Alloys in columbus sells new aluminum at 1.80/lb they can shear to your dimensions as well but they have a cut charge. Their number is 614-384-9714 Ricky is the fellas name that runs it. There is a scrap yard next door that's usually worth the time to walk through.
Reply:Originally Posted by big wormDepending on how much you need and if it would be worth the drive Research Alloys in columbus sells new aluminum at 1.80/lb they can shear to your dimensions as well but they have a cut charge. Their number is 614-384-9714 Ricky is the fellas name that runs it. There is a scrap yard next door that's usually worth the time to walk through.
Reply:Depending on how much you're buying and where you're located, I'd recommend Hadco Metals
GMT+8, 2026-1-2 16:26 , Processed in 0.106673 second(s), 18 queries .
