Bimetallic Transition Inserts
发表于 2021-8-31 22:09:37 | 显示全部楼层 |阅读模式
I'm trying and failing to find anyplace that sells these.I need this to weld alum. to steel so that i can bypass a troublesome bolt once and for all.
Reply:I think the only place that has them is the planet Vulcan on the Star Trek series...... FICTION..........no such thing in joining a ferrous and nonferrous metal together by welding........
Reply:http://www.highenergymetals.com/http://www.nobelclad.com/products/transition-joints/
Reply:Explosive welding
GMT+8, 2026-1-2 16:26 , Processed in 0.102467 second(s), 18 queries .
