Horizontal bandsaw hydraulic?
发表于 2021-8-31 22:09:36 | 显示全部楼层 |阅读模式
http://m.ebay.com/itm/Used-Bimba-1-1...441?nav=SEARCHSent from my SCH-S968C using TapatalkHH 190Uniweld TorchesLincoln 225 ac-sMarquette Starjet torches gauges
Reply:Would this be sufficientSent from my SCH-S968C using TapatalkHH 190Uniweld TorchesLincoln 225 ac-sMarquette Starjet torches gauges
Reply:Sent from my SCH-S968C using TapatalkHH 190Uniweld TorchesLincoln 225 ac-sMarquette Starjet torches gauges
Reply:Or the second?Sent from my SCH-S968C using TapatalkHH 190Uniweld TorchesLincoln 225 ac-sMarquette Starjet torches gauges
Reply:Determine where you will install it.....Then raise saw fully and measure how far cylinder must open to determine if it will open at least that far.Odds are it will be plenty strong nuff to dampen your saw head as it travels downward...So simply worry about it's full travel distance when located where you must place it on saw.Of the two choices, dismiss both..they are not hydraulic...they are air cylinders.Last edited by wornoutoldwelder; 04-13-2016 at 01:03 AM.
Reply:http://bandsawblog.com/band-saw-feed...d-feed-system/
GMT+8, 2026-1-2 16:26 , Processed in 0.079896 second(s), 18 queries .
