My buddy gave me some stainless rod. It's old, but I will still play with it. Funny, I didn't think it would be rusty!"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Kind of odd to see what appears to be rust on the end.
Reply:I still have some I took off a job in the early 1970s. Attached ImagesDont pay any attention to meIm just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:I have over 100 lbs of 347-15 in 8 and 10 lb cans sealed. I understand it is only for certain grades of stainless if expected to perform to specs. I've been accumulating a lot of commercial kitchen equipment (ovens, friers, etc) and plan to cut it up for material. Its likely 304 or 316. Any reason 347 can't be used for various grades of scrap stainless in non-critical hobby situations and for practice? Even to possibly strip the flux for TIG filler rod?30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30" vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:It'll be on its way. No need, I got it for $Free.99But when you get a chance, send out that FCAW squirt gun we talked about, if you still have it. Someday, I will get to test out/play with those new feeders! Something always seems to come up!"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:I have used 308 stainless to weld new exhaust pipe .Years ago, dont think I can do it now.I like welding with stainless.Its expensive but works well on projects.Stainless rods runs very smooth,try it you will like it.
Reply:Stainless rods are an alloy so rusting will happen on old rods.
Reply:Ive used stainless on custom wrenches and it seems to hold up well. Runs pretty good too.
Reply:Looks like you got 308? can't quite read the number but if I remember right 308 is for stainless base material and 309 is a good option for welding stainless to mild steel. We used some 309 at the shipyard I used to work for for welding in stainless hatch rings and prop nut lock tabs. Stainless rod runs great, you probably will run 5-10 amps cooler than the same size steel rod. Good luck!www.facebook.com/gstreetworksLincoln Power Mig 210 Miller Maxstar 150Lincoln Idealarc 250/250 G Street Works LLC
Reply:Originally Posted by Stick-manIt'll be on its way. No need, I got it for $Free.99But when you get a chance, send out that FCAW squirt gun we talked about, if you still have it. Someday, I will get to test out/play with those new feeders! Something always seems to come up!
Reply:347 has a bit more chrome and nickle than 308 + niobium/columbium which ties up carbon for high heat applications... It will work for attaching stainless to stainless and even stainless to steel if you are careful. I've heard the nickname "crackalloy" in reference to 347... I think it had more to do with welding 347 plate/pipe than using it as a filler. I believe the -15 means that the rod is going to run rough.... I believe it has fluorides in it. The weld puddle and resulting bead are really "clean" by metallurgical standards, even if looks suffer. Picture a craptastic casting that is so filled with crap that no weld run with a -16 rod works. They may look pretty but they crack due to contaminants being pulled out of the casting. Switch to a -15, deal with the spatter and rough bead, but no cracks. |
