LINCOLN RANGER 9 WELDER 200hrs So Cal-90712
发表于 2021-8-31 22:09:25 | 显示全部楼层 |阅读模式
I hate to this go. only 200hrs and has served me well. It is currently mounted on a custom frame that I built from 3" sq 1/4" thick tube. But the frame is not included. I just recently changed the oil, gas&fuel filter, new battery, and tank is topped off.    The machine works 100% and you can try before you buy. I only have a ground lead of about 25' and it is also included but no other leads. If you want to make the purchase we can swing by a shop that has forklift to do the transfer of the machine as well or unless you have crane not a problem. Asking $2200.  I am located in So Cal in 90712.  Contact is via pm or email me at wrathje@  gmal.comI will also consider a partial trade, in the works for a lincoln 120v mig + plus cash. Last edited by LMironworks; 02-27-2012 at 03:31 PM.
Reply:GRR,  Can't edit no more, but I;ll go with OBO as well.
Reply:$1700 for the weekend
GMT+8, 2026-1-2 18:28 , Processed in 0.101056 second(s), 18 queries .
