Powder cutting torch Ebay not mine CHEAP.
发表于 2021-8-31 22:09:25 | 显示全部楼层 |阅读模式
http://www.ebay.com/itm/251008048740...84.m1423.l2649Price check these beasts. You'd need to get a powder hopper or make one. http://products.esabna.com/EN/home/g...2%AE_ac4_torchHarris video of what they are good for:
Reply:i don't believe your ebay link is to a powder torch
Reply:It's MISLABELED in the Ebay ad. Common with OA items. Look closely and zoom in if you doubt me. Observe the three hoses, note the model number, and pull up the manual. http://products.esabna.com/index.php...1143059311.pdfOxweld and Purox are now subsidiaries of ESAB. Same torch under same model name is still in production.I'm spending on other stuff and I don't weld/cut/demo for a living. It's still tempting.    Rapidly cut any thickness stainless steel, cast iron and high alloy steels    As simple to use as regular cutting torches    Manual or mechanized versions available    Self Contained    Capacity 10 in. thick stainless    Acetylene or fuel gas    Single lever control
Reply:Your right, good eye.
GMT+8, 2026-1-2 18:36 , Processed in 0.101520 second(s), 18 queries .
