Pretty sure the wife is getting this for me as an Xmas gift, any opinions on it?Ill be using it mostly for round and square steel tubing, steel plate (prob 1/4" Max) and prob some aluminum down the road.
Reply:It will work great for that. For aluminum you may want to get some stick wax type lube and run it along the cut line on aluminum. I have a stick of lenox cutting/tapping paste that comes in a grease gun type tube. Works well for that..http://www.lenoxtools.com/Pages/Prod...uctId=LubeTubeTiger Sales: AHP Distributor www.tigersalesco.comAHP200x; AHP 160ST; MM350P, Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma. For Sale: Cobra Mig 250 w/ Push-pull gun. Lincoln Wirematic 250
Reply:They are good tools, Hardly no sparks and a nice quick cut, But be careful of the noise, They are very loud
Reply:Thanks, glad to hear it does well, noise is least of my concerns excited to get it and get my shop one step closer to ready to tackle anything
Reply:Originally Posted by teknicsThanks, glad to hear it does well, noise is least of my concerns excited to get it and get my shop one step closer to ready to tackle anything
Reply:Lol yea I went through all the YouTube vids I was in the air between the rage2 and steelsaw2, decided on steelsaw2 and then ill get a cheap miter saw for wood (I rarely work with wood)
Reply:hi,i have an evolution steel saw EVO355, was pretty happy with it until i realised it was actually not cutting really square !!! Tried to see what i could do to get the blade and the baseplate more square but i don't see anything to do ! I'm a little disappointed with it nowhappy christmas thoughLast edited by uintas; 12-10-2012 at 03:11 PM.
Reply:Originally Posted by uintashi,i have an evolution steel saw EVO355, was pretty happy with it until i realised it was actually not cutting really square !!! Tried to see what i could do to get the blade and the baseplate more square but i don't see anything to do ! I'm a little disappointed with it nowhappy christmas though
Reply:thanksi did this but the strange thing is when i put a square against the blade it looks alright, but after cutting a tube for example, it's not square ! like the blade is twisted or somethin'Also, i can never get to 45° cut either, at the maximum of the miter, i cut with something like 44° or somethin, so i always get a gap when welding two pieces at 90° ... pain in the a... maybe should try to send it back for guarantee like you said
Reply:Originally Posted by uintasthanksi did this but the strange thing is when i put a square against the blade it looks alright, but after cutting a tube for example, it's not square ! like the blade is twisted or somethin'Also, i can never get to 45° cut either, at the maximum of the miter, i cut with something like 44° or somethin, so i always get a gap when welding two pieces at 90° ... pain in the a... maybe should try to send it back for guarantee like you said
Reply:does the blade last good? and where do you recomend to buy from
Reply:Originally Posted by teknicsOn one of the review sites I saw someone say something similar, the degrees were off by 1 so he had to modify the adjuster, that's something I was gonna check right away. As for wobbly blade it could be blade or motor, I'd def try calling them, from what I read they have good customer service
Reply:I think you guys are trying to use these rage saws for precision cutting and thats not really what they are designed for, If you need something cut accurately you need to use a bandsaw or tack the workpiece up correctly before welding.These saws vibrate a lot, the build in clamp and the bit you adjust for angles is kept to a minimum, Don't try and do high precision work or work which requires 100% acuraccy on these saws, because its not what they are designed to do.They cut, clean, quick , cool cuts with minimum sparks idea for everyday useage but you need to do the precision bit yourself
Reply:Originally Posted by joekodoes the blade last good? and where do you recomend to buy from |
