Source for lifting magnets?
发表于 2021-8-31 22:09:22 | 显示全部楼层 |阅读模式
I searched the forum, not much came up.  I'm in the market for a 200-300 lb capacity lifting magnet.  It would be for bundles of stock, sheets to 1/4", etc.  I've seen several online and was wondering what others on the forum use.Thanks...Enough stuff to build and repair wrinkled up race cars or bring a classic back to life...
Reply:Electromagnet with 200lb lift  - runs on 4 C cells - about $70.http://www.amazon.com/gp/aw/d/B0012N...dir_mdp_mobileJohn
Reply:Are those any good when lifting/pulling at an angle?
Reply:Originally Posted by dstevensI searched the forum, not much came up.  I'm in the market for a 200-300 lb capacity lifting magnet.  It would be for bundles of stock, sheets to 1/4", etc.  I've seen several online and was wondering what others on the forum use.
Reply:Originally Posted by forhireIf I bought more magnets I'd likely buy some like this:http://www.magnetics.com/product.asp?ProductID=1
Reply:the steel yard loads it with a magnet that is variable power and capable of lifting 5000lbs -10,000lbs most likely.    a HUGE difference in comparison to a magnet working at capacity.      picking a bundle with a small magnet is ASKING for a disaster or massive bodily injury.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Originally Posted by dstevensGood point on the lighter gauge sheet but the stuff I have the issue with is 1/8"-1/4".
Reply:Mcmaster Carr is a good source for quality magnets. I would have to agree with others on the use though.Miller Pro 30068 SA 20064 SAF 300305 G Lincoln gasserMiller 210
Reply:Originally Posted by papaof2Electromagnet with 200lb lift  - runs on 4 C cells - about $70.http://www.amazon.com/gp/aw/d/B0012N...dir_mdp_mobile
GMT+8, 2026-1-2 18:19 , Processed in 0.106182 second(s), 18 queries .
