plasma circle cutter
发表于 2021-8-31 22:09:20 | 显示全部楼层 |阅读模式
found this neat tool--http://www.swagoffroad.com/Plasma-Circle-Cutter-_p_45.html  . yeah,it would be easy to build,but at this price,why bother. also,i think one of the dent repair stud welders (harbor freight's is $99 and you might be able to use a 20% coupon ) would give you a sturdy center point if you had a problem with the provided one.miller thunderbolt 250vlincoln square wave tig 175 prolincoln idealarc mig sp250everlast tig 210EXTeverlast power plasma 50chicago electric (hf) 130 tig/90 arcchicago electric 90 amp flux wire3 sets oxy/acet
Reply:keep us posted
Reply:How about this? Attached ImagesMarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:Mark, I really like your circle cutter.  I assume you set the three screws and there is a bearing of some sort in the head?Miller Syncrowave 350Millermatic 252/ 30A spoolgunMiller Bobcat 225g w/ 3545 spoolgunLincoln PowerArc4000Lincoln 175 Mig  Lincoln 135 Mig Everlast 250EX TigCentury ac/dc 230 amp stickVictor O/AHypertherm 1000 plasma
Reply:the set screws grab the insulator, then the aluminum piece swivels inside the steel "lolly".The pivot point is a magnet, but it can be removed & use a 10-32 screw in a hole.  I use a magnet, because many things need a circle without a hole in the center.  On non-magnetic, you can use a magnet underneath.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
GMT+8, 2026-1-2 18:19 , Processed in 0.071151 second(s), 18 queries .
