17 - torch busted -
发表于 2021-8-31 22:09:18 | 显示全部楼层 |阅读模式
in a fit of mad brilliance i managed to break the gas hose - right at the ferrule - i was hoping i could try and thread/tap the large nut to take a barbed fitting and slide the hose back over that and clamp it with a hose clamp - anyone gone down that road before ?  thoughts, comments all appreciated - marc
Reply:why not just get a new hose its not like there super expensiveMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:because i'm of the mind that if you could fix a thing - then you should . i think we all possess the skill to go out and buy a new one. curious if anyone else has done so.
Reply:well- as it turns out - this is a normal fix- your local shop or supplier can provide replacement ends for your hose and a crimp - cost will run around 12$  - it's low pressure for the gas - so not a major deal at all whatsoever . cheersmarc
GMT+8, 2026-1-2 18:17 , Processed in 0.099184 second(s), 18 queries .
