TIG Hand Held Remote Control
发表于 2021-8-31 22:09:17 | 显示全部楼层 |阅读模式
I am trying to find a hand held remote control that goes on the tig torch, in replace of a foot pedal. Does anyone know where I could find one and what style plug it would have to be for a Lincoln Model TIG 300/300 ? Thanks,IR
Reply:Not sure if it will fit your machine, but Lincoln makes a rotary style hand controller.http://www.buyweld.com/k963-3.html
Reply:If you have a real old round top. with two plugs on your remote. you can't get one, the full mag amp current goes through the remote. around 5 amps.once they added the pc board and changed to a single plug, Any lincoln remote can be adapted to it. The low square case all can use any lincoln remote. Just match up the plug.Check out profax, CK worldwide. these are just 2 of many.Know which welder you have before you order a remote. This way you don't melt your new remote.Post your code number If you can't figure it out. Tig 300/300 was made for many years and was changed a lot over time.
GMT+8, 2026-1-2 18:29 , Processed in 0.100491 second(s), 18 queries .
