Wfs measuring
发表于 2021-8-31 22:09:16 | 显示全部楼层 |阅读模式
Does anyone have a link to the video on youtube I think of Chucke2009 or Jody measuring wfs with a little measuring wheel on the drive rollers, think it was a hobart, and had a piece of paper behind rhe wfs knob with the ranges written on it?Sent from my SM-G920V using Tapatalk
Reply:Did you search YouTube?  They both have their own channels.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:YeahSent from my SM-G920V using Tapatalk
Reply:Here:http://bfy.tw/5FSO-Chris
Reply:None of them are that, it was part of a project vid or something, not the main subjectSent from my SM-G920V using Tapatalk
Reply:Just pull the trigger for six seconds, measure how much wire came out and multiply by ten.
Reply:No, I want to see the tool he used to check out my stuff just for the heck of itSent from my SM-G920V using Tapatalk
Reply:Originally Posted by Sharon NeedlesJust pull the trigger for six seconds, measure how much wire came out and multiply by ten.
Reply:Not sure what tool(s) one needs besides a tape measure and stop watch.As much as I admire Lanse's YouTube accomplishments, I can understand why he has the comments feature turned off on this one.  I'm kinda surprised he hasn't just pulled it.I said it when this video was first posted and I'll say it again, if you're going to use this universally accepted method of determining WFS then by all means TURN THE GAS OFF!Second, after a precision "guess" as to wire run-off length with a Carpenter's folding rule instead of the appropriate tape measure, don't just cut the wire off after every setting test - release the drive rolls and WIND THE WIRE BACK ONTO THE SPOOL so you're not wasting all that wire!And finally, I'd stick that probe right up his wazoo if Peter ever poked it thru my MIG gun's cable insulation!!  WHAT ARE YOU THINKING???!!!  Use the output lug(s) you just pointed out!   Oh, and CO2 in that wire data chart stands for Carbon Dioxide not 100% Argon just so you know.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by DJKDNo, I want to see the tool he used to check out my stuff just for the heck of itSent from my SM-G920V using Tapatalk
Reply:Definitely needs a data logging oscilloscope then graph and do a linear fit for the voltage too.  What an idiot, poking a hole through the MIG gun cable.  Guess you can do that when you get stuff given to you for free.    Seriously, Lanse doesn't own a tape measure???  Sent from mobile.  Not responsible for TyposTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:The tool he used was like a miniturized measuring wheel like used for longer distances, and it read out in inches, pretty neat and to be able to use for other needsSent from my SM-G920V using Tapatalk
Reply:Originally Posted by DJKDThe tool he used was like a miniturized measuring wheel like used for longer distances, and it read out in inches, pretty neat and to be able to use for other needsSent from my SM-G920V using Tapatalk
Reply:Thats it, thanks soutthpawSent from my SM-G920V using Tapatalk
Reply:"the correct amount of heat and wire speed to make x-ray quality welds.. . ."just to clarify, i do not mig-weld for a living and am not even good at it.i hate to jump on the band wagon and pick apart a you-tube video, but this part frustrates me a bit. though voltage is important to know, and is the only dial adjustment you get to play with as far as power goes, (well maybe inductance too), it has little to do with the final outcome of the weldment.guys want to monitor their welding, need to put a dc AMMETER to their lugs. with digital displays on xmt's and such it cracks me up to watch guys that think they're "hot" at close to thirty volts and their amperage bounces around in the low hundreds. THAT IS WHAT IS IMPORTANT! cause in that maybe slightly exaggerated case, they are doing it WRONG!i have a lot of fun whenever i do pick up a gun trying to monitor amperage. who cares what the wire speed is, if all you really need to know is higher, or lower to achieve desired amperage. do that for a while and watch your weld quality suddenly improve.bosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Reply:I've never checked WFS or volts on my Miller. I just know where it's right for what I'm welding.                                                MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:I totally understand and relate to the feel sound and sight aspects as they are what I used, I just like checking into stuff I cant afford just to see how it worksSent from my SM-G920V using Tapatalk
Reply:I've measured a lot of WTF's in my day, but not never one WFS."You can't out puke a buzzard"
Reply:A WTF is usually the result of measuring once and cutting once, LOL!!                                                 MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:"You can't out puke a buzzard"
Reply:This method only works on units that do not have a run in when starting.  Units with a slow run in, are programmed to spool out wire at a much slower rate and then ramp up the wire speed rate once the arc is started.  Any measurement made this way will not be accurate.  This includes Everlast inverter MIGS and apparently the new Miller Inverter MIGs.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Originally Posted by CanoecruiserThat guy Peter in Duane's video is beyond belief...why did Lanse post that crap?  Stab the cable with the probe??? Petey should call himself Mr. MIG and hook up with Mr. TIG.  Two-thirds of the Three Stooges...
Reply:To deal with ramp up you could start it and run for a sec the put the wheel down for predetermined time, then read it, but imo not worth it for meSent from my SM-G920V using Tapatalk
Reply:http://m.homedepot.com/p/Calculated-...6020/100324427Sent from my SM-G920V using Tapatalk
GMT+8, 2026-1-2 18:36 , Processed in 0.173425 second(s), 18 queries .
