Mig welding stainless requirements
发表于 2021-8-31 22:09:12 | 显示全部楼层 |阅读模式
Hi, can I mig weld stainless with my Miller 211 75/25?  Or am I going to need a different setup and with a helium tank and different wire?It's a very small job so I'd hate to get this other stuff for one 3/4" weld.  I'm welding a stainless shaft that'll be a permanent key...for a go cart.  My nephews project...not sure if he's got all his facts straight but let's assume he does.Thanks for any help!
Reply:If I understand what you're asking, regular hard wire like ER70S-x and the gas you're describing should be fine for a non-critical component.  Obviously the weld will rust.
Reply:The problem is that it's going to be expensive for a small weld. You'd have to buy a roll for just a small weld. Stainless is not cheap.
Reply:I doubt the shaft is stainless though. Probably a plated steel which you'll need to remove the plating to get a decent weld. easy enough.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Ok, cool...thx!  Yes, ER70-S6 wire.
GMT+8, 2026-1-2 18:18 , Processed in 0.159979 second(s), 18 queries .
