Filling holes in thin hollow section with 6013?
发表于 2021-8-31 22:09:11 | 显示全部楼层 |阅读模式
Using 6013 3/32What is the best way to fill the odd blown hole in rectangular hollow section steel 1.8mm ?MM 180
Reply:I just work a fast bead around the edge of the hole.  Don't hold too long in any one spot.  Skip around.  Eventually, you'll fill it in.
GMT+8, 2026-1-2 18:28 , Processed in 0.074748 second(s), 18 queries .
