Hey guys I've got a ln25 and I'm interested in finding a good welder to run it off of. I'm looking for a single phase unit that is cc\cv. I was running it on my bobcat 225 but I'm interested in buying a shop unit too any suggestions?Miller Bobcat 255Hobart 190 and spoolgunLincoln AC 225Lincoln LN-25Rock and Roll hoochie coo
Reply:Xmt 304.
Reply:Originally Posted by M J DXmt 304.
Reply:I'll vote for the Lincoln V350-Pro! Attached ImagesDont pay any attention to meIm just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by CEPI'll vote for the Lincoln V350-Pro!
Reply:I'm. Miller man myself...... but on this one I would go with the V350 pro with the advanced panel. I used that machine for 2 months in a concrete plant and it is freaking awesome. Welded everything from inconel mig/tig on pipe, welded about a mile of hardfacing wire on a grizzly, and then built all new gear boxes outta 3/8 plate and stick welded them all the way out. In other words that machine didn't skip a beat and it was cold as hell only about 50 yards from the water. But you'll never get my millers hahaha
Reply:Okay I've heard the plug for the Millers and the Lincolns, now here's one for the Thermal Arc. If you can find a TA 400 GMS CC/CV, it's also 1 or 3 phase and multi voltage, if you have the right model, and you'll be in heaven too. It'll do everything that the others will do and has some of the smoothest GMAW performance out there, SMAW is awesome too. Plus it's plug and play with most Miller feeders and their spoolguns. There you go, just find your best deal on any of the above and you'll be set. Good luck and best regards, Allanaevald
Reply:I will second on the TA GMS 400 ,had one for years .I wish I still did
Reply:This works..... Attached ImagesExpert Garage Hack....https://www.facebook.com/steven.webber.948 |
