mobile tig gear
发表于 2021-8-31 22:09:08 | 显示全部楼层 |阅读模式
So I am starting a small side business (hopeully it turns into a real one some day). I am doing mobile tig work. Mostly on kitchen stainless and some small aluminum work on boats. Thats where all my contacts are so I want to keep it simple and just do good honest work. I so far have a ton of clamps. a tig machine, two grinders with abrasives for al and stainless, a portable welding table, a 26 with stuby kit and a 9 flex head, I am buying a bench grinder for tungsten and a portaband. I also have a oxy propane torch kit, I am sure I am missing some stuff but anything that you would suggest as a must have please suggest it.Most the places will let me use there power so I will only be renting a gen when needed for now. I dont have the money for a ranger or anything yet.also sorry I know these threads are taxing but I have read 100 of them and most where geared towards pipe welding rigs. I am trying to fill a small niche market. Latter I want to move into fab work and custom furniture but that is more of a hobby then anything right now.Thanks for your help.
Reply:Just bring enough extra tungsten and other consumables and a large variety of filler.I don't leave home without my handheld tungsten grinder either.An angle grinder, wire wheel and flap disc are always handy to have too.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Thanks brother what filler do you usually pack?
Reply:As for a tungsten sharpener, many use this,  harbor freight  Replacement Wheels for the 120 Volt Circular Saw Blade Sharpener, the diamond wheel bolted to the side of a regular grinding wheel , works well. There are many posts about this. http://www.harborfreight.com/replace...ner-98862.html
Reply:For aluminum and SS a plasma cutter might get you further than a Oxy/fuel setup. An electric Dynafile is an essential for mobile Stainless. You can re-grain #4 finishes to help hide your work with a scotchbrite belt. I like the flat sanding disc with a backing pad better than a flap wheel for blending. If I only had two tubes of filler they would be 1/16" 309L SS and 3/32" 5356 aluminium. Tungsten is easy to sharpen on the angle grinder with an 80gr disc, a dedicated sharpener is a waste. Good luck!SqWave 200Millermatic 190Airco 200 ACHypertherm PM45Boice-Crane Band SawVictor O/A
Reply:Thanks brazin. I too like the backing better. Comes from sanding hundreds of surfboards lol. I am trying to get a plasma also. Hopping to get started in 2 weeks.
Reply:also gotta get a dynafile. I am good with a angle grinder/ big millwauke sander even on delicate stuff but that thing is slick!!!
Reply:Originally Posted by alohacanaalso gotta get a dynafile. I am good with a angle grinder/ big millwauke sander even on delicate stuff but that thing is slick!!!
GMT+8, 2026-1-2 18:19 , Processed in 0.105599 second(s), 18 queries .
