Gate
发表于 2021-8-31 22:09:07 | 显示全部楼层 |阅读模式
Built my first pair of gates, 98x78 each and 20ga sheet riveted.Main frame is 2x1 rectangular hollow section 1.5mmOne came out a bit out of square by around 3/16 even though I used 3-4-5 setup.Used a 1"sq diagonal brace and came out pretty stiff, no sag. Attached ImagesMM 180
Reply:Before I had my table I use saw horses. Always had an issue with keeping thing square. Nothing to clamp to and the horse moves.Lincoln Pro Mig 180Lincoln Pro Core 125Hypertherm 30xpPorter Cable Drill PressAcra 7x12 bandsaw48" sheet metal brakeCrap load of other tools, working on metal now.
GMT+8, 2026-1-2 18:36 , Processed in 0.072388 second(s), 18 queries .
