Lincoln Ranger parts wanted
发表于 2021-8-31 22:08:59 | 显示全部楼层 |阅读模式
I need a polarity switch for a Ranger 8, may be the same for other Ranger series.  I couldn't switch polarity and thought it was corroded, but turns out it's cracked.Thanks, Tom.Lincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:one more time.Lincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:Part number M17014?If you don't have a LWS that carries or has access to Lincoln parts, try Bill's http://www.billswelderrepair.com/parts-page.html or Stumpfs http://www.stumpfweldingsupplies.com/index.html.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thanks Duane.My "local repair center" has it at $98, Kaye at Bill's has it at $104, but I was hoping to find it used as I'm "professionally thrifty" (read tight-***) according to my esposa.  I'll probly order it from Bill's to get the cool stickers And yea, Airgas wouldn't touch it but did give me a repair center contact.Tom.Lincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
GMT+8, 2026-1-2 18:29 , Processed in 0.073556 second(s), 18 queries .
