anybody know what kind of drill press this is?
发表于 2021-8-31 22:08:55 | 显示全部楼层 |阅读模式
I picked it up for $110, seems like a nice drill press, 16 speed:Says "model DT-16F" http://www.philswelding.com
Reply:Looks like an import copy of a Delta. A quick google search pulled up an old auction listing for that number as a Chicago Electric drill press, but they don't show a pict any longer..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:If it doesnt say you know for sure it's chinese. And almost guarenteed to be a knockoff.Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:i would almost bet an older harbor freight drill press.tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:looks like an orbit, a chineese knock offVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Yeah, I was thinking it was a knockoff, but it works ok, better than nothing that's for sure http://www.philswelding.com
Reply:Do yourself a favor and replace the chuck shaped object on the end of the drill press quill. Quality belts wouldn't hurt either with a Power Twist being the best you could hope for. Any good American made belt would be far better than what came of that drill press. I have had more or less the same drill press for the past 23-24 yrs and replaced the chuck with a used Jacobs Super Chuck several years back since the old chuck was starting to give up the ghost. The improvement was amazing...much better than the day I uncrated the drill press all those years before. Run-out was significantly less and it was possible to grip hardened bits for the first time.EDIT: Check the depth lock to see how well the bolt is holding up. The plastic T-knob is a weak part of the design.Lincoln PrecisionTig 275Miller 251Miller DialArc 250Bridgeport millHossfeld bender & diesLogan shaperJet 14 X 40 latheSouth Bend 9" 'C'Hypertherm 900Ellis 3000 band saw21"Royersford ExcelsiorTwo shops, still too many tools.
Reply:Is that  dt-15f or dt-16f model? The 16f seems to be a knock off. Here is a 16f with more picshttp://www.do-bid.com/cgi-bin/mnlist.cgi?dobid166/154Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Does that tag say 50Hz?Tim Beeker.
Reply:No it says 60, where can I pick up a Jacobs chuck? http://www.philswelding.com
Reply:I used one of these on mine.:http://www.use-enco.com/1/1/44002-66...ll-chucks.html
Reply:Originally Posted by MetalMan23No it says 60, where can I pick up a Jacobs chuck?
GMT+8, 2026-1-2 22:01 , Processed in 0.109874 second(s), 18 queries .
