Power Mig 255?
发表于 2021-8-31 22:08:55 | 显示全部楼层 |阅读模式
I may have found a Lincoln Power Mig 255 for $1000 on Craigslist.  It looks a little dirty and beat up from the pics.  Any quirks or issues with this welder.  If I go look at it, anything in particular I should look for or questions I should ask?  Thanks!
Reply:This guy has had this used one since Sept 2011, so he may be good to contact and see how it has gone with over a year of time.  I have a 256 adn have had no problems, and would buy it again. Very little difference in the two. Check with member "snoeproe" , as he had time with one, too.Good luck on your search.TxDoc's Photos Lincoln SP175 PlusLincoln Power Mig 256Lincoln 250 LX Spool Gun Lincoln Precision Tig 225 Hypertherm 600 KMG 2x72 Belt GrinderBaldor 812RE Grinder
Reply:Check with lincoln, a few models had a recall/update for a feeder mechanism issue.  U will need SN to check.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:I have used the 255 at the local high school when I was there helping with the class. They had several 255's. I was impressed with the performance of the machine. Digital display. You wont be sorry purchasing one of these welders.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:I have two power mig 255 is the shop I work at. They get abused daily and never have an issueESAB MigMaster 275Miller Econotwin HFMiller Syncrowave 250
Reply:I asked the man with the video on Youtube how the machine was doing.  He replied:"II have had no issue with the Lincoln since I bought it. It has been around the block a bit from it's previous ownership but so far has not shown any signs of tiring, though I don't put it through anywhere near it's previous abuse. $ 1000 is not a bad price for one that is in decent shape. It's the equivalent of a Millermatic 251, which I used to use on a daily basis when I worked as a welder. This Lincoln seems to perform right on the same level as the blues.Graham Fredeen"www.fredeenblades.comLast edited by TxDoc; 12-26-2012 at 02:51 AM.TxDoc's Photos Lincoln SP175 PlusLincoln Power Mig 256Lincoln 250 LX Spool Gun Lincoln Precision Tig 225 Hypertherm 600 KMG 2x72 Belt GrinderBaldor 812RE Grinder
GMT+8, 2026-1-2 18:29 , Processed in 0.071429 second(s), 18 queries .
