Lincoln SA-250 diesel CV adapter questions
发表于 2021-8-31 22:08:51 | 显示全部楼层 |阅读模式
I recently picked up a 1999 SA-250 perkins with 795 hours on it for a whopping $3600.    I am currently in the middle of taking it apart to clean it and paint it. The FL sun baked the paint right off the roof.   I got to thinking that I might need to run my wire feeder off it.   I was told you need the CV power adapter box or a wire feeder box.  Evidently there was two versions for the SA250s.  My machine was one of the last ones made, so it has the direct plug in connecters under the control panel for the box. Any body got any idea which one is the better one?   Any body got a picture to what they look like?  And of course anybody know of one for sale?Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:For my Classic 300D (4 cyl. diesel Perkins) I got the  CV box (lincoln part # K-623-1).  I got mine from Bakers Gas and Welding Supply (online), for about $1,400.00 NIB.  Had it installed locally for about $400 bucks.The CV box burned out after about 5 hours use.  Factory connection at the  un/calibrated shunt(?) came loose and cooked up some wiring.  Lincoln made good on it ASAP, by supplying new parts, and paying for repair.  Excellent customer service, they even overnighted the parts to the factory rep repairman.  I still have yet to run wire off the box now that it has been repaired.  I will say this much though... the wire was  running like a dream come true off my machine.  Almost forgot... I was using it to run .045 712C dualshield, 100% C02 thru my LN 25.
Reply:Got a picture of what this thing looks like?Lincoln 300 Vantage 2008300 Commander 1999SA250 1999SA200 1968Miller Syncrowave 200XMT350MPA/S-52E/xr-15Xtreme 12vs Millermatic 251 w/30A  Millermatic 251 Dialarc 250 Hypertherm 1250 GEKA & Bantom Ironwokers
Reply:HI Take your 12 VS and set for VV and give it a try we used LN-25 on VV Lincolns and it welds fine with nothing  added both innershield and flux core .  John
Reply:Google is your friend.  Call Lincoln tech, and ask them which CV box is applicable for your machine.http://www.buyweld.com/k623-1.html
GMT+8, 2026-1-2 18:18 , Processed in 0.098473 second(s), 18 queries .
