Can I put a larger muffler on the Weldanpower 225?
发表于 2021-8-31 22:08:50 | 显示全部楼层 |阅读模式
mine has the B&S 16 hp engine on it. I suspect the mufflers are shot, because it is c-r-a-z-y loud! Would putting something like a scooter muffler on it hurt the engine performance?Weldanpower 225 G7Ironworkers Local #24
Reply:The key is to not go smaller in pipe size than the original and/or use a muffler designed for at least the same HP as the engine it's going on.  You'd be surprised how quiet they can be with a small automotive or agricultural (tractor) mufler.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Awesome! My wife and neighbors will be very happy if I can get this put together. Thanks Duane!Weldanpower 225 G7Ironworkers Local #24
GMT+8, 2026-1-2 18:36 , Processed in 0.091179 second(s), 18 queries .
